Brief Description: Upper longeron and skin drilling #2
It only took me two hours tonight to drill all of the right side upper longerons.
Started by making sure the upper engine mount bracket was tightly flush and secure with the longeron and started drilling the #30 holes.
Moved my way toward the rear for the #40 holes, keeping the skin nice and flush with the vertex.
I'm very happy with the results.
I received my front stick back from getting bent by Mike on VAF....not happy about the creases in it. The powder coat isn't cracked and the creases are said to be formed once in a while as a result of the age of the stick and the thickness of it....I just dont like the look of it.
Upper right longeron drilled through the upper engine mount.
